Is there a vendor that can replace missing keys?
Phillipkj4
1:26 AM
Atlanta Ga
Original owner can not find the keys to the car I am dragging home and I would much rather get replacements than buying all new locks,ign etc.
Typically if you pull the lock(s), a locksmith can cut a key to the tumblers. So in your case, you'll have to pull a door and trunk lock to get your ign and door key and the trunk to get the trunk key. Only 'gotcha' is if you happen to have a different ignition key from door lock from trunk. So I have 3 keys but that is only because I've been too lazy to get the door tumblers matched up with the ignition key.
Ok I had ordered keys for VW's from a locksmith how did them off the ign cylinder code. On those you can pull the guts and change into new cylinders etc but was not sure about these.
I can hit a local locksmith up here, thanks
