Is there an easy to install these roller clips?
Redhorse719
12:05 PM
Alburtis, PA
It's been awhile since I was on the site, but now that I am trying to get my 66 Belvedere ready to cruise this summer I need some help with the quarter windows. The repair manual doesn't say anything about the clips that holds the rollers to the regulator. How has anyone that has replaced the rollers installed the clips?
If its like the ones I have done you. lube them and use a socket and a vice to push them on. A work clamp may also work. You just need to get them on a little ways. Do not over clamp them.
Socket and Channel Lock pliers. I think a tool could be made easily.
I thank all that has responded with ideas. I think I will just use E clips instead of the Mopar clip as suggested in the Charger section. It's not like I can get both hands into the opening at the same time to use a tool to install the factory clip. Which brings up " How did the factory install them". They had to have installed them before the quarter was installed. If anyone has any other ideas I would like to hear it. Thanks again.
