Jumping starter relay with momentary switch
Montclaire
11:38 PM
Scranton, PA
Hello, this is on a 73 Dodge. I'm dealing with a hacked up harness and the car refuses to fire off of the ignition switch. It will crank reliably if I jump it at the starter relay. Rather than keep using a screw driver I'd like to temporarily hook up a momentary switch in the cabin. What is the minimum gauge of wire that I should use for this? What should the minimum rating for the switch be?
Thanks
if you want to trigger from the relay... any 16 gauge wire will do the job, between stud and IGN prong. That will make it work just like the stock setup, feeding the SOL output through the relay itself. Stock IGN wire coming out from bulkhead is 18 gauge in fact
Why not leave that type work to chevy owners ?
Normally I would but the car is getting sold and I'm not putting a new harness in before it goes. The harness has several sections spliced in and sections cut out. Am I right in that the prong for the neutral safety just acts as a ground? Wondering if I should try running a jumper to the neg on the battery and see if it cranks off the key. I did inspect the plug for the NSS and it was clean/fit snugly but I did not check it or the NSS with a meter.
I have and use a clip on push button starter switch that does exactly what a screwdriver does. I use it for many reasons including bumping it over for torque converter bolts.
Like I said, I usually overkill. The quality remote starter switched are 12 gauge.
And adjusting valves.
is funny to see 12 gauge wires but that funky weaky clips to hold "suposselly" the load the 12 gauge would hold LOL.
and still being strong clips, the contact surface is minimal related to what a 12 gauge wire is able to handle
The chart says 41 amps for 12 g. I know the relay doesn't take 41 amps to trigger. Unless there's a short or some other issue. I sold hundreds of 12 g. jumper leads and they would come back to me looking like a toaster ribbon. Oops.
I have one of those for testing under hood. Also comes in handy for adjusting valves like you said. The big wire on the starter direct to the battery is where the load is. Those buttons with 12ga are more than capable with those clips to trigger the solenoid.
Since we're on the topic of wire gauge, is there any downside to using a wire rated too big for what you're doing? or is it like a single car going down an empty 5 lane freeway. Just unused space?
