Junkyard 5.7 check?
TDMoparGuy
New Member
2:41 PM
Tulsa
What's is the quickest way to verify that a 5.7 hasn't dropped a valve in the junkyard? Can you remove the throttle body and run a magnet into the intake to check for shrapnel or are you better off buying one of those bore scopes and removing the intake to check down the ports?
Buy at a junk yard that gives at least a parts warranty. I usually get engines from places that offer parts and labor warranty. Next never install without making your own verification. A gasket kit is a lot less expensive than doing the job over again.
I'm wanting to verify that they haven't dropped a valve before I spend the time and effort to pull it.
I guess a bore scope would be the best option, unless you can make the engine turn over with a battery and do a compression test.
