FROSTBITE
I thought i would do a quick write up on what it took to add a MSD atomic system to my 1966 383 Charger.
When I heard about the new msd atomic system is when i decided i wanted to give TBI a try on my car. I did do some research on other systems, but ended up deciding on MSD because i wanted to do a returnless setup.
After i recieved it, i wanted to make sure that i took my time and get all the right extra parts i needed. I went on the MSD forum for atomic and found out the system just doesnt work well setup as returnless unless you are going to mount the pump in the tank. So then i opted to just do a return setup. I ended up spending an extra 500-600.00 on parts needed to do the return system right.
First I Drilled out a hole for the o2 sensor bung on the driver side exhuast. Then welded the bung in using a little 220v wire feed welder. Then Screwed in the sensor and ran the wires up to the engine compartment.
Then I removed the fuel pump and installed a block off Plate.
I Just wanted to make my life as simple as i could on the return system, i ordered a new fuel pick up/sending unit. I drilled a hole in it, then used 6 AN bulkhead fitting and installed it onto the sending unit. Then i used a short peice of steel fuel line i flared then installed a female AN fitting on it so i could conect it to the bulkhead, then bent the return tube away from the fuel pickup.
Installed fuel sending unit into tank
Installed an Aeromotive EFI regulator on the passanger side inside fender.
Removed the carb
Mounted the Fuel pump and filter after the pump to the frame on passsnger side before wheel well.
Routed Fuel hose from filter to the throttle body
ran return line from tank to the regulator
Mounted the MSD power module box to fire wall behind engine.
Installed throttle body
installed another fuel line from other side of the throttle body back to the regulator
Installed the temp sender
Made the all the wire connection
Drilled a hole in center console base and routed the hand held programmer to inside of the console, so i can just open it and pull out the programmer and read info while inside of the car
Adjusted the throttle body blades
Programmed the ECU
Started the engine up and checked for leaks
Installed a 440 ram air cleaner for a 4 barrel on top of the throttle body
Removed the carb
Programmed the ECU
