I have a 64 4dr Fury 361 and 727 mostly all there but front clip, would like whole car gone to someone that could use it. cheap. if you can come get it.
If I was retired, I would probably be seriously considering it. But as it is, it would take too many days off from work to make it worth while. Thanks for the reply.
I've a pretty clean one pulled out of a 65 earlier this summer.
The small or big block will bolt up to these. No need to buy any conversion kit. All the difference is on the engine side of things. I've switched engines many times on this vintage. $200 for my k member. I'm about 45 minutes North of Rochester, Mn. I probably have some brackets for big block too I could sell pretty cheap. You'd just need to buy the rubber insulators.
