Keystone Klassic wheel question
70Hemi-RR
12:01 AM
Colorado
I bought new Keystone Klassic rims for my road Runner. After looking them over the center section is aluminum and the rim itself is steel. They are welded together. I always thought you could not weld steel and aluminum to each other. Anybody have any insight into this? I’m worried that joint won’t be strong enough with the blown hemi and four speed that I’m running.
All opinions are welcome.
Dennis
a lot of guys like s&m ran them . are they klassic or kustomag . kustmag are direct bolt . klassic are unlug .if you unlug i wont run them with a lot of power and the if car hooks good
Cragars are made that way as well. Sox and Martin ran them for years.
The tires I have aren’t very sticky so I’m hoping it won’t stress them too much. If I go to the track I will run slicks on some stronger rims.
Thanks for the replies.
Cragars, Keystone, the like, have a steel plug, called a clip iirc, embedded in the end of each spoke, which is welded to the steel hoop.
Are you sure about the costruction method? I think maybe you will find the center welded to a hoop that is riveted to the main hoop.
Pretty sure no one can weld aluminum to steel.
Definitely welded. No rivets
I discovered those lengths of steel imbedded in the ends of the "spokes" when I was trying to figure out how my Motor Wheel Spyders were constructed.
Thanks for the "Ulf" reference.
I've been searching for some one to make 15x7 out of 14x6 for years.
Maybe he can.
Dennis
Ya know I always thought the sameway . I wanted to at 1 point in time make a set of " D- Ralleys " wider so I gathered up a set of Cragers. What I found was steel encased with aluminium that was welded to the rims. So I think you'll be fine with nothing to worry about.
Can't speak of the quality of wheels today, but back at the garage in the day, we routinely replaced grandma wheels with (YOUNAMETHEBRAND) wheels. Some guys took their cars to the track. We never heard of a wheel failure. For track cars a popular choice were Centerlines.
NOT A PROBLEM. My old C/Gas racecar used to leave with a clutch dump at 8500rpm with 12" M&H slicks. Did this for years without any wheel problems...
