Kids, Permanent Black Markers, Classic Cars Don't Mix
I've used that to clean up old cylinder blocks but would hesitate trying on a finished vehicle.
Whatever you're going to use, try it in an inconspicuous location on the car first to see if something "bad" happens.
I didn't realize you had single stage paint. I wouldn't try the easy-off.
My 928 has a clear coat that is hard as nails. Gets harder with age? It's a 1979 model.
Goof off. Just did some rust repair on my Lincoln. I used it to get fresh overspray and primer off for spots I was working on. It took fresh paint and primer off but didn’t hurt the original factory paint. If the markers are fresh I’m sure it will work. It has to be Goof Off and not Goo Be Gone.
Acetone will remove marker but just remember, Acetone is what finger nail polish remover is made of so unless you want to take the paint with it, don't use acetone!
Yikes!
Try drawing on a whiteboard with permanent marker. Then draw over the line with a dry erase marker and immediately wipe it off. It will typically remove the permanent marker.
My two youngest sons decided to do that to each other when they were a out 5 and 6. It took a couple days to fade away from their skin. Mom wasn't happy I thought it was hilarious. I have the pictures somewhere
Yeah, tough one. Isopropyl Alcohol (IPA) is my go to for removing Sharpie marks but since you don't have a clearcoat I'm not sure how that's going to act. Painters correct me if I'm wrong but single stage (acrylic / lacquer) never truly cures and can have the color wiped away with solvents (which would include IPA). Might try in an inconspicuous area but don't loiter any place too long. Also might see if you can cut the IPA with some water. The aerospace guys I worked with often used IPA cut with water as a cleaning solution.
I use lacquer thinner on established paint usually. Generally I have a cloth and a bucket of water sitting there to neutralize it and wipe with the lacquer thinner as gently as it takes. It usually will evaporate before harming the paint anyway.
If you're scared of lacquer thinner just compound the marker off.
I have a Duster with a rattle can black underhood paint job, that I wiped off most of it using Goof-Off and Acetone. From the smell of them, they are basically the same thing.
I use alcohol, if it's a sharpe marker. Watch using oven cleaner, if it gets next to a paint edge, it's coming up.
Me too; 99% rubbing alcohol usually takes care of Sharpie marker, but the fresher the marks are, the better...and the less porous the surface, the better.
Do not use oven cleaner on a painted surface. That **** will remove aluminum anodizing. That's what I use it for, actually. Anodize removal and polishing
I was just watching a Project Farm video yesterday on scratch removers because I have a few light scratches in the clear coat on my Scat Pack.
For his tests he actually drew lines with a marker on the paint on a car’s trunk lid, to highlight places he’d scratched the paint for testing the different products. All of the products took the marker lines off quickly. Several did nothing towards removing scratches but still took the marker lines off fast.
His tests were on a base coat clear coat finish, so I’d test on an inconspicuous area first before getting carried away using them on single stage. But might be ideas here that would do the trick easily to remove the “artwork”.
Reminds me of the first RollsRoyce I ever saw in person. The owner of Blue Diamond Trucking from Baltimore Md. His sister lived beside my shop where he was visiting. He was showing me the car and I asked what happened rear door and rear fender because it looked like hail dents but on the side where its not probable. He said the grandson found a ball peen hammer and was having fun.
Now, if you only got a damn BLACK car in the first place !! You wouldn't have this problem ! :lol:
