LA 318- Timing Chain Recomm and Timing Cover
5:30 AM
Sticks
Hey Moparheads...
Need some quick advice!
Looking for a good source for timing cover for LA318 not the Poly Motor.
Also... Best timing chain for Street use... Just to replace old chain... Motor is basically stock- lil head work.
Just trying to get a newly aquired car on the road.
Thanks!
I used a Cloyes C3028X chain and Cloyes 9-5387chain tensioner on mine. I used a Magnum timing cover since I am going with a serpentine belt drive. Make sure if you use a double roller chain, that you go with .250" diameter rollers and the rollers are solid, not split. The above chain part number is such a chain.
