LA 360 Engine Torque Spec's Needed
OutLawBiker
10:10 PM
MEDFORD, OR 97501
Hey Everybody,
I blew a head gasket on my bird and need accurate torque spec's and sequences. Any recommendations on stock head bolts lube or lock tight or?
Here's the low down;
la360
340X heads
Erson Cam Hot Street ET Bracket - .472/296, 106 L/C, Hi Flo I H
Headers
Edlebrock 7576 Air Max Intake
Holley 750 Vacuum Secondaries
Please offer suggestions in my situation-
Much appreciation-
Thanks, Jackson
torque them to factory specs using motor oil all over the bolts. make sure your bolt holes are clean to the bottom of the holes, start from the center of the head and work to the ends in 3 steps. Make sure your heads are flat. if not have them milled flat.
