Lares 11033 PS gear issues ?
It has less power steering assist at highway speeds.
They don't just tighten the lash more.
Pictures would be good here.
The drivers side header (and starter) will need to be removed.
You will likely need to remove the motor mount bolt on that side and jack the engine up a bit on the drivers side to faciliate removing the header.
Note that the roll pin to remove the coupler from the box comes out more easily in one direction so look closely before you try and punch it out.
You will need to loosen the column and pull it back from inside.
Plan on some time for this with headers it's not the easiest of tasks.
Note too that you should replace your pressure hose if it's original and flush the box/line with clear fluid before connecting the new box.
I just put this box in a couple of weeks ago in my 67 Charger. I don't have headers, I had to raise the engine, and I removed the battery tray and removed it from there. I could feel right away the play in the wheel was gone. I still have some work to do with changing the lower control arms and a new wheel alignment before I know for sure.
