LCA ball joint pressed in?
vanrj1
8:21 AM
Dixon
Are the lower ball joints pressed in? These suckers won't come out. beating on it with a pickle fork, no luck. Well using a hammer on the pickle fork....lol
Lower Ball Joint is pressed in.
See pic below. I hope it helps.
I'm at work, if home I could show you a better picture.
"Super-bee_ski"
PS: I'm pretty sure I just banged the lowers out w/ a hammer and when I installed the new ones, they just "seated in" when threading in the bolt.
(I've done two sets of K-members with suspension so far)
I'ts the "upper control arm" that requires the "specialized socket"
I forget everything lately, I'm getting old...
:iamwithstupid:
Try hitting the lower control arm where the ball joint passes through a couple of times.The shock will normally release the tension on the ball joint taper.Follow with the fork again if needed.
RT
A pickel fork is really meant to be used on tie rods.
Try this: Use two hammers. One on one side of the LCA where the tapered ball joint stud goes thru, and hit the other side, opposite of the other hammer.
(hammer)(LCA)(hammer)
The stationary hammer helps transfer the energy into the LCA loosening the stud. Kinda like using a hammer and dolly when doing bodywork.
The socket I have for the UCA ball joints is Snap-On S9365A. They screw out.
Hope this helps.
Make sure you are using a good size ballpeen hammer or a short handle sledge. A small hammer will get you nowhere.
Ken
Thanks for the info, I added a little heat and they practically fell out. Just wanted to make sure they didn't have threads like the UCA joints.
You do mean the lower ball joint right ? They are bolted in. Ron
