location for 4 sped hump- 64 Savoy
barbee6043
11:50 PM
S E Texas. Shepherd, texas
Can someone give me measurements to properly locate the hump, reference to the firewall and to the side at say the sill?? Thanks!!
I had to fab the floor (has original tunnel) and the repop hump is not that great.
Knowing that all the floors in mine were really not exactly where everything was supposed to be I put the trans and shifter in and then installed the hump...
I would do that IF I had the eng. I have the trans, no bell.
IF no o e buys this project I will finish it and keep it for my last build.
Welding in the hump helps eliminate the buyers that want it as an auto. car maybe!!
If you have the transmission and the trans crossmember and a shifter that is all you need...
It may take a little time to make sure it is centered up and at the correct height but that could be done with measurements...
You are correct. Never thought of it that way!!!!
