Loose wire
On my 70 beeper, that molded 3 way connector is up under the heater control if you remove the 4 screws at least on mine
Thanks everyone for your input. Looks like I have options in trying to correct or just leave as is. It is a column shift automatic car but even if I get the wires straightened around it may not work if the bulb or it's socket up in the column is not there. There reasons why previous owners leave things unplugged 99 percent of the time. At this point not a high priority and not worth removing steering wheel to find out. I thought maybe just to plug the loose end (bullet style plug) into the empty slot on the connector just to see if things work.
