71Beeper
- 9:36 PM
- Nov 28, 2010
- Stoney Creek, Ontario
On my 71 Runner, while I was putting it together I tested all the circuits for the tail lights & everything was good.
Just by coincidence while I was pumping the brake pedal with the car in the garage I glanced in the rearview mirror to see if the tail lights were coming on & they were not.
At first I thought maybe the key had to be in the on position for the brake lights to work (my wife's Austin Mini is that way) but I knew that was not the case.
So tonight I started in the trunk when the rear harness plugs in. Since the battery is in the trunk, I supplied full 12V power to each prong on the harness plug and each light was working just fine - even the license plate light works.
So I plug that harness back in and go to the drivers kick panel where the next plug is.
Unplug it and proceed to run full 12V power thru the rearward harness to confirm it's not the wires themselves.
No issues - as I applied 12V power to each wire I got lights.
First the black wire with yellow tracer (I think) and everything lights up - this is obviously the nigh time lights.
Next I power the green wire and voila - drivers side.
Next I power the brown wire and the passenger side lights up.
lastly I power the violet wire and I get the reverse lights.
So now I look at the plug that coming from the main harness side.
With no key in the ignition, my test light shows the 2 pink wires (joined together) having power.
Looking on the plug going to the back of the car those 2 pink wires connect into a grey wire.
Since I didn't see that grey wire in the wire harness plug for the tail lights am I safe to assume that is for the fuel sending unit?
So, my dilemma is - with the key on I get no drivers side signal but I do get the passenger side one.
Here's the weird part, when I tried the 4 ways, the fronts worked great but the rear drivers side marker bulb was flashing as was my dash cluster night time lights!
Both front side markers were flashing but dim.
Sounds like something was back feeding to the wrong place.
Any of you guys had similar experiences?
