43tutor
I started my new motor a few weeks ago but the motor just doesn't pull a lot of vacuum. Around 7-8 inches at idle of approx. 900 RPM.
The motor is completely fresh. 400 block bored .020" over, it has a 470 stroker kit installed, 10.3 compression. 452 heads that are ported per Mopar performance templates. Cam is a MP #P41220235 (.484 lift, 284 duration, 241 @ .050, 108 degree lobe separation) factory hydraulic flat tappets. Intake is an Edlebrock 383 performer, carb is a TQ 850 CFM (#6322).
I have checked for leaks on the intake manifold by spraying around carb cleaner around all joints, no change in RPM. I have remove the carb and made a Lexan plate to bolt on top of the intake and use a small bead of RTV as a gasket. The plate has to 1/4" NPT fittings. One for a PSI gage and the other for air inlet. I removed the rocker assemblies to make sure all valves were closed. I pressurized the intake to 5 PSI and it held pressure for several minutes with only a very slight decay in pressure.
I checked the all vacuum lines and found no leaks. Brake booster is completely rebuilt (Booster Dewy's work). No leaks at booster.
I degreed in the cam and my numbers only varied by 1 degree from the cam card specs. The cam is advanced 4 degrees.
I have tried the timing from 5 degrees BTC to around 20 BTC. No change in vacuum. Stock distributor.
I have removed the TQ carb and installed an Edlebrock that I borrowed from a friend. Same issue with vacuum, about 8 inches.
I'm wondering about the intake manifold. In the manifold directly below the carburetor there are two holes that appear to go in the EGR passage. I bought this intake used, without any installation instructions. Should those holes be plugged. The holes are not threaded. I checked on Edlebrock's website but didn't find much information. The holes are open to the EGR passage, which is the crossover passage from head to head (am I thinking right ????). The passage is open to the exhaust valve.
What are your suggestions.
