Lower control arm bushing tolerance
beebest
2:39 PM
Uniontown, Ohio
I'm rebuilding my lower control arms on my 70 road runner. I purchased proforged bushings from Summit. I have the stub shaft installed into the bushing using 12 ton harbor freight press, no problem. For the heck of it, I miced the OD of bushing and it measures1.470. The ID of control arm mics 1.460.
That's a heck of an interference fit. What should fit be? I haven't tried pressing it in yet as I want to make sure of correct tolerances first. Thanks for all and any help.
Never measured them, bought correct Moog bushings and pressed them in. My small press is 10 ton, never a problem. Forgot what the Moog number is.
We found the pro forge to be tough to press in.
Never measured them.
But .010" is quite large, I'd consider turning them down to .002 - .003 over
Thanks, I'll have them turned down. I only have one side apart. I'll work on the other side tomorrow.
Like Rem says and it's a shell around rubber... 10 thou is nothing.
When we installed them we used my log splitter as the press. They were extremely tight I've got a 9 hp motor on it and the governor was kicking in hard, way more than necessary. I've always installed them dry?
