Lower control arms.
Cordoba78
3:30 PM
Vikebukt (westcoast of Norway)
Hello.
I am in the process of rebuilding the front suspension of my 1978 Cordoba.
The lower control arms are in bad condition, the torsion bar anchors are very loose and sloopy, and the right hand control arm is a little bit bent, it looks like it has been hit by something.
My question is, where is the best place to get a pair of used lower control arms in decent shape?
I see in your profile your overseas not sure where you could find controls arms, but I would say probably gonna go and hunt junkyards. There a few places in the states but not sure if they would ship overseas found this on ebay
https://www.ebay.com/ulk/itm/391231671302
I have a set of lowers that came off a 73 charger not sure if they fit yours but I don't mind shipping over seas as long as I'm payed and the shipping gets payed for
Let me know if mine will work for you . I'm asking $50.00 for the pair plus shipping
As far as i know, the 75-79 Cordoba and the 73-78 Charger use the same lower control arms, so yours should fit, but it would be fine if you had some pictures so i can be 100% sure they are the same.
They are the same. I have a set as well both removed from a 75 charger but one was originally from a 73 with the screw in ball joint someone tacked in a regular one.
They need some cleaning up and new bushings... here's my add on kijiji (as I'm in Canada)
http://www.kijiji.ca/v-view-details.html?requestSource=b&adId=1118465927&siteLocale=en_CA
I can provide more pictures if you like. I will ship but shipping wont be cheap I'm sure you being overseas.
I have just found out myself that the 73 control arms have the screw in ball joint.
I would prefer control arms with the press in ball joint since i allready have a front end kit with new press in joints.
Can anyone recommend a salvage yard that might have a set of control arms?
I sent Wildcat mopars a request about a week ago, but no answer so far.
Are you still looking for a set? I ask because there is a 78 Cordoba in the upull it yard by me... I have already taken the brakes and spindles
