Thanks but it's it's a little to up for meWhy?? That stance looks good. I have some old 67 GTX springs that would probably do the trick. I replaced with new springs to get the back end back up.
do what you want with your car and I'll do what I want with mine
Speedway sales a nice aluminum block with a 9/16" centering pin. From 1/4" up. The ss springs and 30" tall tires was a little too tall for my liking. I installed 1.5" blocks on my '65 Belvedere and it dropped the car 1". Just make sure the "U" bolts are torqued and surfaces are clean.
Build what you like. They can build what they like.
View attachment 777324 View attachment 777327
Boy that looks good I like the way your car sets man looks nice I like that I like that old super stock look looks awesomeSpeedway sales a nice aluminum block with a 9/16" centering pin. From 1/4" up. The ss springs and 30" tall tires was a little too tall for my liking. I installed 1.5" blocks on my '65 Belvedere and it dropped the car 1". Just make sure the "U" bolts are torqued and surfaces are clean.
Thank you so very muchCouldn't have said it better myself. .......When those cars were new they did sit level so you're actually returning it to originality (somewhat) but he was probably just to anxious to give you **** to notice that.
That's a really nice car you got I like that that thing was killed I like the stance on it too it's not too high in the back but yet not too low niceSpeedway sales a nice aluminum block with a 9/16" centering pin. From 1/4" up. The ss springs and 30" tall tires was a little too tall for my liking. I installed 1.5" blocks on my '65 Belvedere and it dropped the car 1". Just make sure the "U" bolts are torqued and surfaces are clean.
I'm running 2" lowering blocks (part store truck lift blocks) & the only problem I've had is I had to modify my adjustable pinion snubber to be shorter. The cheap parts store blocks have worked well for me for over 10 yrs.Curious if anyone here lowered there car with ( Lowering Blocks on rear leaf springs and if you did what brand did you use and would anyone have any pics of Before & After.
I have a 66 Plymouth satellite i want to lower the back at least 2" Thanks for any help or Info.
ck springs.Are the springs new? If so, they will likely settle down a bit over time.
When I got my car as a roller it had 1" lowering blocks like these. I took them off since I did not think they were needed with the new wheel & tire combo on my car.
https://www.summitracing.com/int/parts/aaf-all56130
No sir they are super stock springs.Are the springs new? If so, they will likely settle down a bit over time.
I agree sir with what you said and i was going to raise the front up 1" i just feel that with Super stock springs its going to need the blocks to come down some.. Before i had a little smaller rear tire height wish and a tall tire up front and it looked good. here are a few picsI'm not gonna tell you what you should or shouldn't do with it. It's your car. Now that we got that outta the way, lol, if it were mine, I would mock it up with the front up maybe another inch and see if that works for you, instead of dropping the back down. If you like the look, it's simple to accomplish. I get the feeling, that's the real difference in the look that OSDart has accomplished with his '65. That and those sweet wheels he's running are exactly what I would do, lol. My two cents.![]()
I really like the change looks awesome my friend.Speedway sales a nice aluminum block with a 9/16" centering pin. From 1/4" up. The ss springs and 30" tall tires was a little too tall for my liking. I installed 1.5" blocks on my '65 Belvedere and it dropped the car 1". Just make sure the "U" bolts are torqued and surfaces are clean.
View attachment 777324 View attachment 777327 View attachment 777522
