Magnum force drop spindles/wilwoods
dodge68charger
11:11 PM
Washington
Im really leaning towards magnum forces 2 inch drop spindles and 13 inch brake kit they recommend using on my 68 b body. Anyone use their setup and had any issues. Going to run a 18 inch rim up front. Heard the tie rod end might hit. Im using 11/16 tie rods if that makes a difference..Thanks
No experience here but I'm interested to hear because I'm planning the same thing.
i have the drop spindles and the wilwood brakes. their gear is really good and i recommend, the tie rod should not hit with 18" wheels
The bigger the wheel, the more tie rod clearance you will have. The front wheels I have are 18x9 with 4 3/4" of backspace. I have about 7/8" of clearance to my tie rod end.
