Master compatibility?
mmissile
10:04 AM
Motown
Going from 11" drums to discs on the front. Chances of the stock master working properly?............
Thanks, Mike.
Okay.....next question. Does anybody know if the drum-brake residual valve is in the master, or proportioning valve? Calling on the experts here.
I think your master will work,it did for me. When I replaced the single reservoir,I bought the cast master for a 67 Plymouth. When I installed SSBC front disc kit,I also installed a prop valve,but it turned out I didn't need the prop valve.
Thanks. Trying to keep it looking stock under the hood.
You should use a different master cylinder when going to disc's. Pirate Jack or The Ramman have the correct one. It has the residual valve in the front reservoir for the rear brakes.
