I disconnected the old single pot master today. I went into the car and pulled the brake pedal backwards, and felt the pushrod pop out of the master. I then removed the four nuts under the dashboard holding the master, and my hands look like mincemeat. When I went under the hood and tried to pull the master out it seems to be hung up. Is there something else I need to remove, or could the studs just be jammed in the support plate?
