Master Cylinder mounting
jdhreiss
5:00 PM
SW Washington
I've installed the Master Power Brakes manual front disc conversion on my 67 Bel II and the master cylinder has the 4 bolt flange that replaces the 2 bolt flange on the original. Is there a adapter plate for this or do I need to fabricate one? Thanks in advance.. Joe R.
IIRC 66 is 4 bolt and newer style is 2 bolt.
Also pwr m/c has holes as studs are in booster.
Manual has studs and nuts go on inside of firewall (pain).
I'd like to know about an adaptor, though.
Seems like it would make the rod too short.
I'd like one simply to not have to deal with those inside nuts.
Master Cyl
The front disc brake kit I got was for manual brakes, but it came with a 4 hole master cylinder. It also shows the 4 holer in their installation instructions. I think I'll contact them monday to confirm if this is the right m/c.
