Master cylinder push rod
tracy
8:53 AM
indiana
How does the rod come out of the master cylinder ?
It takes a real tug, you can't hold it and do it ffor the most part.
On the car I just unbolt it and pull it away from the firewall. Insert a block of wood between the master and firewall. Then pull up on the pedal.
It's amazing how much force it takes to get that little rubber grommet out.
The block of wood is just a temporary spacer to allow you to use the leverage of brake pedal to pull the rod out of the MC.
Wrap the wood in a rag to prevent damage to the paint, if that is your concern.
When I took my old MC off, that thing was in there real good. That grommet holds on for dear life. A few swings of the old hammer & she came out, but initially brought the piston and all with it. A few more swings and the rod was free. :D
OMG after they have been in there for years it grows to the rubber. Good luck and give it hell.
That's actually a pretty important point,, I did one this summer that ripped the piston out,
And boy was there a splat of brake fluid everywhere. Be careful
