Wietse
Hey guys,
My car had been parked for 2 months in the garage, since it was nice weather today i took it for a drive.
Later on i found a small puddle of oil on the garage floor and as it was very thin oil i suspected it was brake oil.
After some checking i found an oil trace coming from the flange between master cylinder and brake booster, so guess the rod seal is gone.
Does anyone know if there are still rebuild kits available for these cylinders?
I checked Summit and Classic Industries but did not find any.
It is for a Disc/Drum setup with Bendix brake booster on my '69 Coronet R/T.
Should be with 1.125" piston, my actual cylinder has the ports on the engine side of the body, the one below shows opposite side though, for the rest it looks identical.
