Master cylinder
Dave66
4:07 AM
Silver Creek, New York
I just purchased a manual disk brake conversion kit for my 66 coronet. I know I need a disk brake master cylinder, does anyone know what year, make and model I could use? I plan on buying new from Napa.
I think that you should be able to use a 71-76 A or B manual master cylinder. I put the disc brake setup from a 76 Volare on my 69 Bee. If you did not get a proportioning valve, you will need one for the disc setup. The drum valve is different from the drum/rotor valve.
