Kmrumedy
Hi Guys,
I have a 64 Polara running an Indy 528 Street Legend Hemi. It is has Milodon Deep Sump 7 quart oil pan with the Milodon big block mopar dipstick with flexible tubing.
During standard oil check maintenance, the dipstick connected with something and the last 3 inches of the dipstick broke off into the pan.
I'll have to drop the pan to get it out. (Magnets don't work and I couldn't find it using an endoscope. Even if I did locate it, I'll never get it out of the drain hole.)
Question - All this aftermarket stuff is new to me. There is a reusable Fel-pro gasket currently in place. I bought a new one in case I tear the old one taking off the pan. Internet says normal torque specs for Milodon is around 15-18lb feet torque with reguar gasket. Does anyone know what the torque spec would be with the Fel-pro? OR do you tighten to feel? I'm used to stock pans. Any help/suggestions are welcome.
Thank you.
Thank you.
