RoadRunning
Hello,
I bought this CVR 1338 Mini Starter from Summit Racing because the other starter I had was barely touching my headers on the back corner of the main big part. I bought this one to try because says it has 10 clocking positions which I am hoping will give enough clearance from the headers once I clock it a bit. Why these things do not come with any good instructions I will never know but I have some questions that hopefully you guys can help answer:
Thank you in advance for helping with your knowledge.
- There are 5 positions on the top of the bracket to clock to and 5 on the bottom. It appears that I can only clock to 5 positions unless it allows me to swing the whole thing 180 degrees. Do you know if this is possible? Otherwise it looks like it really only has 5 clocking positions.
- The bolt hole on the top of the bracket appears to be larger than on the bottom of the bracket. Do you know why? Shouldn't they be the same size to match the hole they are bolting onto?
- There is a large black rubber drip tube thing at the end of the main starter big piece. Once clocked, this hose thing might touch my headers. Can the hose be cut? I don't really remember seeing this on the starter I returned but maybe it was there..
- Anything I should be aware of regarding the nose cone?
- Any other information I should know about this thing?
