mopar big block flywheel
steve maluk
8:33 PM
johnson city tn
hello all
i fired a 440 on a firing stand with a big block 11 inch 143 tooth flywheel. i want to fire my 540 hemi to break cam in on the same stand with the aluminum bell housing that i have that bolts up to the hemi. I know that i need to get a hemi flywheel do i purchase a hemi 11 inch 143 tooth flywheel. will the starter that i used to fire the 440 work on the hemi with the same bellhousing
thanks all
The starter used on the 143 tooth FW should work with the 130 tooth with a possible exception. I believe some mini starters may have clearance issues with the block as the starter is closer to it with the smaller (130 tooth) FW.
The factory 143-tooth is a 6-bolt Wedge flywheel although it is available in the aftermarket in the Hemi 8-bolt configuration. The '66-'69 Hemi wheel was 172-tooth.
The '70-'71 Hemi used the 130-tooth and same aluminum housing and starter as the Wedge.
