mopar muscle 2004+ FSM
erk_f-100
10:56 PM
Saetre, Norway
Does anyone have a copy of the Mopar Muscle march 2004 article on A-833 rebuild gear grabbing i could buy? I'm trying to change tails / rebuild my A833.Also needed is a factory service manual. I have the 70-74 non overdrive A833. Or just anything else that would help!Thanks Erik
73 Charger front bumper Question.
I'm stumped, 3 years ago when I removed my front bumper, after marking everything, I removed it as an assemble. I very carefully marked the front valence, hood and fenders before I removed them.
Now with everything painted and lined up on the removal marks. I cant get the bumper to go back far enough to bolt the braces to the car. The top goes back fine, but the bottom needs another inch.
Before I disassemble the bumper anmd put it on in pieces. I hope some one has some suggestions. I've found that the outside brace to bumper bolt can't be got to with the grill supports installed.:confused:
this is two different threads. Patrick you should have started a new thread in the body section. those in the know call this a hijack. someone who could help you may not see your post if looking at titles only. try it again as a new thread
