WTB Mopar Perf Max Wedge Heads
PlymouthGuy
1:29 AM
Kansas City, Mo
Feedback: 1 / 0 / 0
Looking for unused set of Mopar Performance Max Wedge cylinder heads. Casting number 2406518-M. If you have some collecting dust and not going to use them let me know.
Thank you
Those heads in MA have been cut for either stainless or copper wire sealing. So you will be pretty stuck running a copper head gasket. which really isn't a big deal as long as proper RA finish is completed. It looks like intake bolts are helicoiled...again no biggie, as long as they are straight. I would inquire about exhaust seat install. There is not much "meat" in oem seat area, and its not uncommon to cut into water jacket. If seat is installed there will be a insert lip on port floor...might cause some reversion, Dwayne would be more qualified to answer this than I.
If you buy them as seller to measure thickness of intake mounting flange on both heads, and the deck surface ..meaning from top of lower bolt boss to deck and be able to compare how even thickness the heads are. Those are oem heads, just who knows how much they have been hammered on over the years.
good luck i use to work for mopar me and my boss checked the whole us through mopar looking about 8 yrs ago none to be found i found some used ones on the internet but they where one with the bigger valves also i had a old coworker check again last year no luck they need to make them again
I know where this set is. P5249579. They are MWPW. Jim LaRoy aka IQ52 built them along with his son Cody a few years ago. They are brand new never used. Kim
