426Roadrunner68
Went from a really good day to a really crappy day on Sunday. We got the Roadrunner out this weekend for the first points race of the season. Winter changes were a new bolt together ATI 8" converter, new valve springs, new valve covers, new valley plate, new spark plug wires. This is the first race with the new bolt together ATI converter. I get in the car friday night during test and tune. Car left great, felt just like it always did with the Turbo action converter. I get the time slip, I am stunned. 5.66 at 120.34 MPH. WOW. A new best. Next hit, track got tight and air got cool, car did a hell of a wheelstand (not intended), ran another 5.66 at 120 MPH. Ok cool, we got a good setup. Ready for the next day. My dad is a good bit heavier than I am, roughly 50 or more pounds. I am always a few hundreths quicker in his car due to the weight difference. Saturday, air is no where near as good, he gets in the car, goes 5.73 at 119 MPH. Next pass, has an issue. Not sure what happened. Had a big bog and backfire. The gasket that sits between the carb and hood seal somehow broke in half and was stuck in the secondary throttle blades. Ok. Race rained out saturday and they were racing both points races on Sunday. First pass, 5.75 at 118.67 MPH. Ok this is exactly the same difference as we all slowed up due to even worse weather conditions. Heard what I thought was a header leak, ok we will check it out later. First round, runs another 5.75 at 118 MPH. Gets the win. Come back, lets check out the header leak. Actually its coming from the rocker area, not the header. Pull the valve cover, check for broken springs, burnt up pushrods, broken rocker, etc. Get to #8 intake, its got no lash. Ok wtf. Pull rocker off. Pull pushrod out, broken tip down at the lifter. Wow. Ok thats it for the weekend. Got home, pulled the intake last night, tip is laying in the lifter cup. Lifter bore is scarred up but no excess metal anywhere. Pried the lifter out of the bore and am going to do a leak down test to make sure no valve is bent. Took off work tomorrow to see if me and my engine builder can fix it for Dragway 42 next weekend, or if we need to pull it out and take it apart.
Will post pics after I take some later today or tomorrow.
On a brighter note, I jumped into the bottom bulb class for the first time in 11 years with my Demon. First time EVER using the trans brake off the bottom bulb as I used to footbrake the car before going top bulb racing.
Sure as ****, 7 rounds later, God parked me in the winner circle. Wow, couldn't believe it. Overall hell of a weekend. Now onto getting ready for 42 Mopar race next weekend.
