Motor and Trans mounts
Steve K
7:26 PM
Pittsburgh
Slowly working on getting a rebuild 383 put into my 73 Charger. We are expecting to have about 530 HP out of the build. I was going to get new mounts, and am wondering if I should get poly mounts or if rubber mounts will be sufficient. I can only find inserts for the poly units but complete mounts with the rubber inserts.
Thoughts?
Poly mounts are stronger. But, You will get vibration transfer in to the car. That is unpleasant for anything but a race car. The 73 uses spool type mounts, engine and trans. Not the flat ones on the engine that pull apart like on previous years.
I used poly for everything except the engine and trans on my 73. Stayed with rubber for those.
