Andrew
Hey Guys.
Had my Coronet running fine for a short time, and suddenly shut off. Turned out to be the magnetic pickup trigger inside the MSD 6al. Had it repaired and 10 minutes after I had it running it suddenly shut off again. Tested the box, same issue. The white wire (points trigger) still would fire the box, but the purple and green would not. I saw a post from 2010 with the same problem, but no answer. Any ideas? Motor is well grounded with battery cable to the frame.
Thanks
Thanks
