Multi gear oil weight
Bleep Bleep
11:50 PM
Pittsburgh
440, Manual steering, A833, Dana- I’ve used SAE 80-90 in trans, and diff (with limited slip friction), but didn’t have manual steering.
Confirming all three can use same multi-purpose gear oil weight. Service manual indicates yes.
Thanks!
Thanks! I looked it up and that would be distributed by a grease gun? It’s that heavy of a weight product?
It's almost liquid, it's a zero weight grease. I put it in a soup can, warm it on a hot plate and pour it in. You could also use a grease gun with just an open hose on it and stuff as far in as you can b4 pumping.
I like the John Deere Corn Head grease as well. Use it in the steering sectors of my old Ford tractors. I keep a specific grease gun loaded with it.
FSM says fill it to covering the worm gear? If that’s correct it’s definitely low right now. PS conversion on the winter horizon …
Thanks guys!
