my 70 Satellite
Early
New Member
12:08 PM
nc
So I finally got a decent day and a day I felt good enough to work on the car. i got out and put a new fuel pump in, plugs, wires, and new cap and rotor. Points looked good so left them alone for now. Changed oil and flushed brakes and coolant system. Started right up and idles good. Took it for my first ride in it and ran as good as a 50 yr car should. She seems to die when letting off the gas to stop or turn. Did run out of gas but that's my fault.. Tank leaks at the seams so can only run half a tank for now and the gauges aren't working on her yet. Cleaned up the floor pans and only found a few small pin holes on the driver side. need to replace all the brakes front and rear, might get to that tomorrow.
glad you had a good day playing with the car,did I miss the pics of your car?
