Yes, definitely keep your vacuum advance - a car driven on the street needs vacuum advance to handle high vacuum, light throttle driving.
Your timing mark is dead on zero?I brought the car into town today to have my engine builder listen to it and see what he thought. He liked the way it ran, and when we put the timing light on it, it was about 16 degrees initial and 38 total. Once we hooked up the vacuum advance it jumped to 34 initial and 56 total, which he felt was way too much. I promised to try it without the vacuum advance for a bit and see how it acts and whether it has any effect on my overheating issue. He said too much advance can be as bad as not enough as far as overheating is concerned. If I find a difference, I might take the distributor out and recurve it over the winter and possibly try to limit the total vacuum advance, so I can still use it.
In my humble opinion, therein lies your problem!. A Holley? But you may be excused due to the fact it’s not stock. Certain you will get things sorted out.Yes, the balancer is new and the timing marks were verified Don. No fuel injection, still messing around with the Holley.
Only ran 50 degrees on two engines....neither were stock but both had really low compression and ran like crap with less timing. I actually used 3 different timing lights the first time I ran into that to make sure my lights weren't lying to me.Fwiw, When utilizing vac advance, my preference is to set it up so the max it can reach is about 45*.
This generally requires either a pretty slow mechanical curve and a fairly normal vac can(basically like a stock distributor with low initial timing), and/or a vac can with a pretty short travel.
I’m sure plenty of people run them at 50+ , but I’m going to pass on that.
Wonder if that's the newer one with the adjustable mechanical advanceThanks for all the responses. There has been a minor change of plans. I went to a swap meet this morning and picked up a brand new MP distributor. It says it has a performance mechanical curve. I am not sure how much vacuum advance it has. I am going to put it in and see what kind of timing it has. I did find an article about how to limit the vacuum advance .
It says it has 22 degrees of mechanical advance on their website. Also appears to have some light springs. I tried to tighten the vacuum advance adjustment a bit before I put it in. We'll see if it works. I am just waiting to borrow my buddy's timing light tomorrow, since mine bit the dust.
So it looked like a regular mechanical advance mechanism?While I was out in the garage I installed a quick change vacuum secondary kit on the Holley. Yes I like Holleys, and I don't have much use for Carters. It had the stiffest spring in it so I swapped in a lighter one and we'll see how it works.
