My new stock stroke 400 build
While I was out in the garage I installed a quick change vacuum secondary kit on the Holley. Yes I like Holleys, and I don't have much use for Carters. It had the stiffest spring in it so I swapped in a lighter one and we'll see how it works.
It's always best to change 1 thing at a time and then test.
So, you found Mopar parts at Ancaster? Weird. I wanted to go today, but had to be a Grandpa, instead. Beautiful day; must have been a great turnout!
Dave
Huge turnout at Ancaster, Dave. The guy was selling new parts and he actually had another distributor in a kit with the wiring harness and orange control box. Both were for B engines, what are the chances of that?
……and for the secondary vacuum diaphragm spring, if et matters to you, the track is the only place to test it.
Yes, I know Don, but my garage time is limited, so I kept working. I can test the total timing without even getting into the secondaries.
When I took my engine builder for a ride he felt that I might be a touch rich, but I am not going to change the jets until I have a good baseline. I'm really interested in seeing if the change of timing stops my temperature creep at cruising speeds.
I checked the new distributor out today. I set the mechanical advance to 35 degrees at 2500 rpm and found I had 25 degrees at 1000 rpm. I continued running it up to 3500 and it kept slowly advancing up to around 42 degrees. I left it like that with the vacuum advance disconnected and took it out for a ride. It ran fine with no obvious pinging, but it made my overheating problem worse. I checked a spark plug and it seems like now it doesn't have enough advance.
I ended up pulling the initial back to 20 degrees and hooked the vacuum advance back up to ported vacuum. It looks like it topped out at 48 degrees total. I'm going to try running it like that and see how it acts, and if it helps the overheating issue.
Your distributor should be able to give you about 20 - 24 degrees of mechanical advance. It should start coming in around 1000 RPM and be "all in" by 2800 to 3000 RPM.
I had my Road Runner (with your old engine) at around 36 degrees total timing (initial plus mechanical, no vacuum). On the dyno, I actually picked up power reducing my total timing to 34 degrees.
Yes, the distributor I built for the 500 had specs like that. I had to unhook the vacuum advance when I ran it.
This distributor is supposed to have 22 degrees of mechanical advance. It appears that with one super light spring, I am getting some mechanical advance at idle. I should probably change out the heavy spring so the total advance comes in sooner.
I am going to try it as is right now since this car cruises at about 2500 rpm, so with the centrifugal advance not all in yet it may actually balance out by reducing the total advance at cruising speeds with the vacuum advance connected. If I am pulling over 3500 rpm I probably have my foot in it, so vacuum advance is not in play.
For Don Frelier I did make several full throttle blasts to check the secondary opening with the new spring and it is better and no bog. Now with the quick change top I can change springs in 5 minutes.
I reset the timing today, back to 15 initial. Due to the slow curve in the new distributor that only gives me 26 degrees centrifugal at 2500, and 37 total at 4000. I hooked up the vacuum advance and it was 48 total at 2500 cruise rpm. I went and filled it with gas and took it for a long drive down to Port Dover for a photo op. It may be the last time this year! The good news is the temperature held pretty steady, but then again it was only about 50 degrees Fahrenheit today. The plugs looked pretty good too.
Man, you are a brute for pulling spark plugs on an engine that is just ignorant for that chore!
There is a mistaken belief that a bigger cube engine needs bigger carb jets. Sometimes. Sometimes not. More cubes create a greater depression [ vacuum ], so more fuel is pulled out of the jet. Self regulating, you might say. A great example in the MP book. TQ used on the 340-360 engines used a 0.169" sec jet. On a 400 engine, 0.137".
The stock '60 413 I had used a 575 cfm carb.
