nchrome
nchrome
1:37 AM
Galesburg Ill
Well there's not much to say except that l bought a 69 charger 383 engine auto trans column shifter buddy seat between buckets. Car didn't look bad till l got it home and started finding all kinds of problems. Rear frame rails trunk floor front floor pans torsion bar crossmember rotted and lots of bondo. l live in the rust belt area and suppose to of been stored in a garage for 30 years but my guess is 20 out in the yard and ten in a garage. l've already replaced both frame rails, trunk floor, shock support cross member,fuel tank filler neck, spring shackles and perches ,rear cross member, right rear quarter,both front floor boards, and one front frame rail and the search for the end of the tunnel goes on. haven't figured out to post photos just yet and l have a lot of them to post Oh found it hope it works
Welcome.
Looks like you got some work ahead of you
Welcome to the forum....
Create a build thread here in the restoration section...
I know the feeling,stay strong its worth it.Take it 1 step at a time.
Hi nchrome, thanks for sharing. It looks like you're jumping in with plenty of enthusiasm. Oh, and :welcome:
Thanks for the pics, look into other projects here in the forum, and you'll see that everything is possible.
https://www.forbbodiesonly.com/moparforum/threads/500-68-charger.46289/
or the Don charger, those are amazing cars.
https://www.forbbodiesonly.com/moparforum/threads/dons-1969-charger-restoration.51122/
Bienvenido desde México btw.
l would visit these sites but for some reason l lost that forum and can't get back on really urks me but what ya gonna do. l've been on there a lot and did join but today lost it and can't get it back
Welcome! There's plenty of help here to tap into. Start a thread to keep track of your progress, it will keep you motivated as you go back an look where you came from!
One positive to take away is that at least you have a car that has just about every part repopped....some are not quite as lucky!
Welcome from Ohio.
Welcome to FBBO from SoCal. A good coat of wax should get her looking just like new.....
Welcome, looks like you will be busy. But you have a car worth working on and you can get almost any piece of metal for it.
Stick with it hope it turns out the way you would like. You will have something to be proud of.
