Need 1970 Road Runner trunk opening dimension
JDR1967
3:40 PM
Louisville, KY
Hello,
I am restoring a 1970 Road Runner which was damaged on the drivers side quarter panel and trunk drip rail. I am ready to replace the drip rail and removed the quarter panel but need to verify the inside dimension from drip rail to drip rail(weatherstrip removed). It appears that it is 47" at the tail light panel and tapers to 46-3/4" at the dutchmans panel but not positive. Does anyone have an illustration they can share showing this dimension or check their original. I don't know if it should be 47" from front to back or 46-3/4" from front to back or if the taper is correct. Thank you very much for your help.
I can check my original tonight if nobody replies beforehand.
I hope this helps
99205CB1-2958-4093-B0C7-4FEB3A1CBAB5.jpeg 5076683C-D0C2-43BD-B953-CA32E8DBE1F9.jpeg 5AEE72B7-46DE-4A85-813E-99B0CFF2E4D4.jpeg E65E83F6-380A-48FD-B73E-9749FD819042.jpeg
