Dan64
You may want to look through Derale's produce line up to see if there is a dual fan/shroud unit that you could make work . I used one from them them but it was on a 26" Cold Case. I had to modify it a little but it worked out pretty good, pulls around 4100 cfm but you have to use separate relays and you need a decent 140 amp alternator ( they draw a lot). You gonna want separate relays so they don't come on at the same time .Yes thats what i understand also plus a pusher interferes with my AC condenser.My mounts on my radiator will give me the gap space in need really i just need to get someone to put 2 90 bends on a piece of aluminum then i will cut new holes where i need them.
