Need block translation
Jeff Erwin
8:03 PM
Woodinville, WA
I finally got all my plugs replaced, 3 from under the car. While I was under there I found some of the block stamps. Anyone care to decipher these?
I think it's telling me the engine block was cast 11/4/69 but I'm not sure about the number with the -7 at the end. Also what is the little dial below telling me?
D.N arrow is showing Night shift. Clock shows time. -7 is casting revision or mold. Not exactly sure.
-7 means 7th time this mold was used.
It is generally used 10 times before discarded unless
a major issue is found in the casting
The one arrow shows Night shift. The other arrow points to the time of shift. Note that there are only 8 dots to point at; as in 8 hours in a shift. So, it is not really a clock ( that would have 12 dots ), but shows the casting was done in the last hour of night shift. The -7 would show how many times a core section has been replaced due to out-of-spec dimensions. A new core would be -1, so this one has had 6 replacements.
So, last hour of night shift, casting repaired/used 7 times out of 10, this thing IS GONNA BLOW!!!
RUUUUNNNNNNN!!
Wait, it runs perfectly. I'm so embarrassed...
