Need Carter AFB #4732 Specs
soundhd
8:18 AM
Ann Arbor Michigan
Need the specs on a Carter #4732 Carb. Have a 70 RR (383; Auto & A/C). Currently has a Cater AFB Competition #[FONT=&quot]9636 (625cfm:[/FONT][FONT=&quot] Metering Rods 70x47, Primary main jets .098, Secondary main jets .095, Orange power piston step up spring[/FONT]).
Correct carb is the #4732. Cannot find the specs on the 4732 (while doing a search came across a posting on another Mopar site that said maybe a 4732 is a 650 or 670 CFM). if that is the case the 9636 that is on the car now is too small (CFM wise anyway).
Have checked all the carb sites that I could find but have not found any specs on the 4732.
Pulled out my old service manual-68..How about AVS-4429s(440HP,auto)..pri.jet-.101",sec.jet-.089"..1-11/16" pri.&sec. throttle bore.. Or--4401S(383,auto) pri.-.089",sec.-.089,,,throttle bore 1-7/16pri.,sec.-1-111/16"(#4429 was on my Super Bee from the factory) 383HP,auto..Cannot remember cfm ratings; but both were less than 700cfm if memeory serves. Step-up rod was supposed to be #16-546 on both carbs.(mine was a 16-547)??? Go figure.Oh, main venturi-was 1-3/16" on 383 and 1-7/16" on 440.(((for everyone's info--Hemi-frt-pri.-.089",sec.-.080"",rear carb- pri.-.89"L,.089"R, sec.-.092"L, .077"R)))
