1970-318 want to order but not sure which ones. Standard bearings and just a cruiser. Looking on RockAuto More Information for MAHLE / CLEVITE CB481P8 and More Information for MAHLE / CLEVITE MS540P would these be the right bearings? Thanks
What I was saying is the 318 has a high volume oil pump, so am I good with stock bears?If you have the proper clearances you should be ok with a standard pump with a half grooved main.
Engine was already built,tore it done because it sat for over 15 years. Already had the H V oil pump in it. Thats why Im asking about the bearings.just a crusier? then stick with stock half groove mains and stock oil pump. you don't need a high volume pump.
