Rat Rod Al
Anyone know what this is exactly ?
I keep finding old and a bunch of new ones.
Thanks in advance.
Thanks in advance.
YEP.. metal ones are a good find! Picture in case you want to know how many to make up a set!Look like clip that holds under hood insulation on.
Thanks , pics are good. just the clips used or is there a big flat washer under it ?YEP.. metal ones are a good find! Picture in case you want to know how many to make up a set!
The ones I have , have a big slotted hole to the right of the small one with the switches in it, in your pic. What is the big slot for in mine ? Under the radio.All 1970 b-body with a standard dash and A/C. Non A/C pictured below.
So this means all Belvedere, satellite, sport satellite, coronet deluxe, coronet 440, coronet 500, and coronet R/T with standard dash.
The cover plate for the column opening and the ash tray itself are both specific to rally dash or non also.
The metal part that screws to the dash to hold the ash tray and lighter is the same on all 1970 B-body dashes.
A/C ventsThe ones I have , have a big slotted hole to the right of the small one with the switches in it, in your pic. What is the big slot for in mine ? Under the radio.
