Need some help please, Charger driver window plastic pin
benno440
12:21 AM
australia
winding up my window then bam the window fell down into the door, pulled the card off and window and window track roller have fallen off, found a green plastic pin, sitting down the bottom seems to be what holds the track roller onto the window and it is broken, any clues on what it is called or where I can get another?
thanks
If you can't find the plastic grommet and pin set, I've used these well nuts.
The rubber protects the glass, and I use a plastic washer on the other side, where the bolt goes through.
thanks guys, sixpactogo that's the one, thanks yy1 I might get one of those as well, any idea where from?
I bought mine from RT specialties, there's also some sort of gasket that goes in between the glass and bracket that they sell too.
managed to find some new ones here in Australia form pentastar parts. $16.50 for the both, still cheaper than postage and our **** dollar rate at the moment coming from the us.
thanks for the assistance guys.
