karki
If you have a 8.7:1 compression, .030" over 383, and you take off a 84cc head and bolt on the 75cc head you will go to 9.4:1 compression. If you take off a 88cc head you will gain a full point of compression.
Though the E-Sreet head is the same casting as the RPM head, is is NOT hand blended in the runners under the seat as the RPM head is and is not CNC'd in on the intake entrance and the exhaust like the RPM head.
Tech couldn't tell me the shape of the combustion chamber when I asked yesterday.
Even though they use the same size valves (2.14/1.81), they use cheaper, heavier valves, lighter valve springs, and harder valve seat inserts in the heads. Because of these design changes they are not ment to be used in high performance (racing) applications. The harder seats will tend to cause valve bounce at high rpms but should last longer in street driving conditions. The lighter springs and heavier valves limit the rpms to about 5500.
You still are required to THINK about what you intend to do in the future with your engine build. It may be a great stock head replacement for street driving but is not ment to be a race head. You may be able to force it that way if you replace the seat inserts, valves and springs.
But, if you want a 75cc head for racing, get the Victor.
So lets say im thinking on putting a comp cam XE285 in my 383 and put that head on it wont work even if i change spring to comps recomendation?
could something broke or will it just not giving the power that the eddy rpms should? // peter
