- 5:18 PM
- Sep 16, 2020
- Washington state
The engine is in and ready to be started. It has been on a Dyno so there should be no issues. When restoring the car I bought a new engine wiring harness that I thought I needed. I went with the one to convert it to electronic ignition. I now found out the Mallory Unilite distributor that I have does not need a ECU to operate. I pick up the Mallory unit for real cheap with hardly any use so I'm not out a whole lot of money. I replaced the ballast resistor with a 10 gauge wire to look stock and hope this is correct in that electronic ignition does not need the resistor?
At this time the move would be to go to a performance Mopar electronic distributor that will just plug into the new harness. The harness came from Evans wiring harnesses. What Mopar performance distributor are you guys running? I hate to say it but Mopar Ignitions are my weak spot.
