New here can someone help me decode 69 RR
Kato1
9:31 AM
Los Angeles
Hi I'm looking to buy a 69 RR wanted to see if someone can help me decode the tag.and what you guys think is it a good deal?
"1969 Plymouth Roadrunner 383 stock Engine,727 Auto transmission,Original Engine not original color it was avacado green could use new paint,%5 percent rust around back window,,small tear in front seat,clean title odometer says 128,240?, fender codes are posted,do not have original wheels."
00W0W_b1uCDrzB9pq_0gl0t2_1200x900~2.jpg 00E0E_3Q3f4YUh3P4_0CI0lM_1200x900.jpg 00p0p_iB6a631o1HN_0CI0lM_600x450~2.jpg
F5 med green metallic paint
383 4bbl
Automatic 727
You can see original paint on corner of tag, what other info would you like to know?
Thanks i appreciate it. I wasn't sure if the green was the original paint. They are asking 19 k. What you think?
From the photo it looks nice.
But with any Collector car, devil is in the details.
Is it the #'s matching Engine and trans?
Any build sheets?
How is under the car, solid original, or solid repaired, quality of repairs.
IMO:
If it looks as good as the photo I see, and it runs and drives, it looks nice.
Also I am not good with Lynch Rd fender tags.
I think tag also says its a bucket seat console car.
He said it's a matching numbers engine and trans. I'm see if I can get pic of underside. No build sheet.
00G0G_6MxzsH8F8GM_0CI0lM_600x450.jpg 00303_UmxFFQX6Qn_0CI0lM_1200x900.jpg 00D0D_7KbXrHVfgOi_0CI0lM_1200x900.jpg
I would not take his word on it being numbers matching. If you don't care, then no problem.
One way to find how much bondo is on it is with a magnet. Wrap it something thin that won't scratch the paint anymore than it is. I see a missing back on the passenger seat. Kinda hard to say if the price is good or not based on just a few pics.....
Got you.. thanks for your guys help. I will be getting more pic. And doing more research on it.
Look at the ID pad on the 383, by distributer, should have E for 69 and HP for 383 roadrunner
Depending on early or late build 69 the engine will have the full vin # stamped by the oil pan rail, or partial vin.
Transmission also should have the car's vin, to be #'s matching.
Isn't a RM23 car a Satellite, where a real RR is a RM21? Just checking.
RM tells us it’s a Road Runner
21 tells us it’s a two door coupe body
23 tells us it’s a two door hard top
A Satellite is RP
Welcome from Missouri!!
