New lower quarter 74 roadrunner
4:35 PM
North Dakota
Has anyone installed new lower quarter panels on a 74 roadrunner?
I am looking for tips or things to watch out for, to help make this go easer. Any information would be great
Just did on my 73
IMG_20131108_183430_570.jpgIMG_20131108_190211_546.jpgIMG_20131108_195441_794.jpgIMG_20131110_115042_903.jpgIMG_20131116_150119_663.jpg
took a full weekend for one side, the driver side was already repaired but i did do some work to make it look nice
put the new panel up to the car and traced it, then took a grinder with a cut off wheel and cut inside of the line. Hung the new panel using these http://www.eastwood.com/intergrip-panel-clamps-set-of-4.html
tack welded, then just made tack after tack (no bead welds) on the whole panel. grinded down using a cut off wheel since its more precise then used a flapper wheel to smooth everything out.
Used body filler anything that wasnt even and sanded down
Thanks how long did this take did you do both sides
:eusa_wall:also make sure your trunks empty so nothing catches fire :eusa_wall:
We are in the process of doing my 74 right now. Have the right side installed. Only thing we did that was not described in above posts was we used a crimping tool on cut edge to put a step in metal so new panel would sit more flush . Punched holes in new panel and welded through holes to new panel. Used a weld through primer between panels . replacement quarter RR.jpg
Should start on other side this week hopefully. Good luck.
